ASUS ProArt StudioBook Pro X
Create more with a secondary display
ProArt StudioBook Pro X is the first Quadro®-powered laptop to feature the four-sided NanoEdge display, making it a mighty powerhouse that brings ideas to life. The innovative slim-bezel NanoEdge design allows a larger panel to fit into its compact chassis for immersive visuals. Powered by up to 9th Gen Intel® Xeon® or Core™ i7 processors, ProArt StudioBook Pro X offers outstanding performance, while its NVIDIA® Quadro RTX™ 5000 GPU ensures a graphics prowess that’s second to none. The addition of the interactive ASUS ScreenPad™ 2.0 makes working a breeze, too. ProArt StudioBook Pro X offers a combination of cutting-edge graphics and portability that makes it perfect for creative professionals.
DESIGN
The first Quadro laptop with the four-sided NanoEdge display
ProArt StudioBook Pro X is the first Quadro laptop to feature the four-sided ASUS NanoEdge display. The innovative display design provides a 92% screen-to-body ratio for immersive visuals.
DESIGN
The 17” RTX Studio Laptop that fits in a 15” briefcase
For a 17-inch laptop, ProArt StudioBook Pro X is surprisingly compact. It has a footprint comparable to that of many 15-inch laptops, enabling it to slip easily into your briefcase or messenger bag for professional-grade graphics wherever you go. It’s bound to turn heads, too: its Star Grey finish with Rose Gold highlights gives it a classy look.
PERFORMANCE
Top-notch performance to fuel your creativity
The remarkably compact and versatile ProArt StudioBook Pro X delivers next-level performance, and will handle anything you throw at it with minimal fuss. The latest Intel processors and NVIDIA graphics, along with ultrafast storage, let you blitz through the most demanding tasks faster than ever before.
CPU
9th Gen Intel Xeon / Core i7 processors
ProArt StudioBook Pro X is powered by a 9th Generation Intel Xeon or Intel Core i7 hexa-core processor designed to handle complex, multithreaded applications. These processors take mobile computing to another level, easily outperforming previous-generation offerings to give you incredibly smooth and responsive multitasking.
GPU
NVIDIA Quadro RTX 5000 graphics
Seamlessly edit your creations and render multilayered files with professional-grade NVIDIA Quadro RTX 5000 graphics. This DirectX® 12-compatible graphics monster delivers all the horsepower you need. Advanced RTX features like hardware?accelerated ray tracing ensures stunning visuals, while exclusive AI assistance reduces repetitive tasks for faster content creation.
DISPLAY
Photorealistic visuals
The 17-inch NanoEdge display on ProArt StudioBook Pro X is truly awe-inspiring. This WUXGA panel features 8-bit color depth, a wide color gamut, and exceptional color accuracy to ensure pin-sharp detail and bright, vivid colors for more lifelike images. Designed for professional use, it also has a matte finish so there’s no distracting glare.
SCREENPAD 2.0
The Intelligent touchpad, evolved
The new ScreenPad™ 2.0 upgrades the traditional laptop experience, adding an interactive secondary touchscreen that enhances your productivity with more possibilities. Its intuitive smartphone-like interface lets you easily manage tasks and create your own seamless multitasking workflow. There’s a series of handy ASUS utility apps to boost productivity including Quick Key — for one-tap automation of complex keyboard sequences — along with Handwriting, Number Key and Office Xpert. There are also useful quick controls that improve the interactions between the main display and ScreenPad: for example, you can now launch a video or chat box — or many other apps — onto ScreenPad to take advantage of the extra space wherever you are, and without interrupting your work on the main display.
SCREENPAD 2.0
More possibilities
ScreenPad™ 2.0 intelligently fits many apps into the 5.65-inch touchscreen, and you can effortlessly add apps to ScreenPad for instant access. The newly-optimized ScreenPad experience ensures that your favorite apps, such as Evernote® and Spotify®, will work perfectly on this secondary display right away, without the need for a ScreenPad-specific version. ASUS also works closely with third party developers, including video-editing software developer Corel®, to optimize adaptive ScreenPad tools for the ultimate productivity — and there’s much more to come. Get ready for the ScreenPad revolution!
EXPERIENCE
Easy sharing and hotkeys
ProArt StudioBook Pro X has a 180° lay-flat hinge that allows it to be fully opened and laid flat on a table, making it easy to share ideas and designs with clients and colleagues. In addition, several dedicated hotkeys give you the convenience of capturing screen grabs or locking the system with a single key press.
CONNECTIVITY
Gigabit-class connectivity
A comprehensive set of high-performance I/O ports — including two Thunderbolt™ 3 ports — give ProArt StudioBook Pro X the ultimate, hassle-free connectivity for versatile flexibility whether you’re in the office or on the road. You can event connect ProArt StudioBook Pro X to three external displays. It has gigabit Ethernet, and is one of the world’s first products with Intel Wi-Fi 6 with Gig+ (802.11ax) so you can enjoy wired-equivalent network speeds — without the wires!
ISV
For creatives, software is key. That’s why ASUS tests and invests in comprehensive ISV (Independent Software Vendor) certification processes to ensure ProArt StudioBook Pro X works as expected with professional applications from the world’s leading software companies.
AUDIO
Stunning sound
DURABILITY
Militarily tested durability
ProArt StudioBook Pro X meets the ultra-demanding MIL-STD 810G military standard for reliability and durability, undergoing a punishing test regime that includes extended tests for operation in harsh environments including extreme altitudes, temperatures and humidity. It has also passed ASUS internal laptop tests that far exceed the standards set by the industry.
