Tester
The supremely portable ProArt StudioBook Pro 15 is the most compact model in the range, but it still packs a big punch when it comes to performance. Its powerful NVIDIA® Quadro RTX 5000 Max Q graphics make light work of graphics-intensive tasks, while its 15.6-inch PANTONE® Validated 4K UHD panel ensures pixel-perfect imagery every time.
DESIGN
Lightweight metal chassis
StudioBook Pro 15 is an extremely portable workstation you can take anywhere, thanks to its thin 18.9mm profile and overall weight of just 2kg. Its reinforced metal chassis is more durable and resistant to everyday wear and tear, ensuring it looks good in and out of the office. The three-sided NanoEdge design boasts 7.5mm-thin top and side bezels, giving StudioBook Pro 15 an 82% screen-to-body ratio for immersive visuals, as well as a more compact footprint.
PERFORMANCE
The power to create
StudioBook Pro 15 offers you the perfect balance of graphics, performance, and portability. As a creative professional, you’ll appreciate its powerful Intel® Core i7-9750H processor, NVIDIA Quadro RTX 5000 Max Q graphics, and dual-storage design as you blaze through everyday tasks and content creation.
GPU
Professional-grade Quadro graphics
The professional-grade NVIDIA Quadro RTX 5000 Max Q GPU delivers performance in droves, allowing you to easily tackle graphics-intensive tasks such as 3D rendering, video editing, and content creation.
CPU
Supersmooth multitasking
The 9th Generation Intel Core i7 processor delivers incredibly smooth and responsive multitasking performance to take mobile computing to the next level.
DISPLAY
Detailed 4K picture quality
The 4K UHD panel on StudioBook delivers 4x the detail of FHD displays. This PANTONE Validated display features 100% Adobe RGB color space and Delta-E < 1.5, offering exceptional color accuracy for highly-detailed photorealistic visuals.
THERMAL
Comprehensive cooling for performance and longevity
The comprehensive cooling system uses a mix of hardware and software to ensure optimal cooling, whatever the task. Six heat pipes draw heat away from the CPU and GPU, and the ultra-thin copper fins of the four heatsinks also help dissipate heat efficiently.
CONNECTIVITY
Comprehensive connectivity
StudioBook features comprehensive I/O ports so it’s compatible with a wide range of devices and peripherals. In addition to the USB 3.1 Gen 2 Type-C, there is a USB 3.1 Gen 2 Type-A port and two USB 3.1 Gen 1 Type-A ports for essentials. There’s also Display Port over USB-C, and HDMI 2.0 for 60Hz 4K UHD output to external displays.
ISV
Optimized software
For creatives, software is key. That’s why ASUS tests and invests in comprehensive ISV (Independent Software Vendor) certification processes to ensure StudioBook works as expected with professional applications from the world’s leading software companies.
AUDIO
Impressive audio
Get ready to give your ears a treat! ASUS SonicMaster Premium goes beyond the ordinary to give you an audio experience like no other. Developed by the ASUS Golden Ear audio engineering team, its stereo configuration delivers immersive full-range, multilayered sound with rich, thumping bass and sparkling highs.
